Turn signals and emergency flashers
GMC
CMJ116
2000 s-10 pickup L4. Left turn signals will not work nor will the emergency flashers. The right side turn signals work fine. Can someone tell me what the problem might be ?
Jan 15, 2006 at 5:21 AM
MMCGUIRE1014
There is a plug in type relay that does the turn signals and flashers. It is usually on the fuse panel. It is not very expensive. There are different ones, so if you get the wrong one, the turn signals will flasher at a different speed.
Jan 16, 2006 at 1:26 AM
