2000 Buick Park Avenue Shift Jolt
GMC
JUSTINPAUL411
  • 10 POSTS
Once again on my mothers 2000 Buick Park Avenue I notice after driving it a while, when shifting from reverse to drive, or park to drive, or what have you the car moves foward, and if you have your foot on the brake it kind of jults foward. Not hard... but harder then a luxury car should.
My 2002 PArk Avenue shifts without any movement, and I dont notice it EVER.
The dealer says the transmission needs to be flushed and thats whats causing it... because there is no lube between gears
Is this true?
Feb 6, 2006 at 6:11 PM
MVANNESSJR
  • 223 POSTS
How many miles since a transmission flush? You should have the transmission serviced every 30,000 miles. The fluid should be red in color. If it is low or brown in color I would recommend this anyway. With the engine warm and running, and parking brake on. Shift to drive, then to park. Remove dipstick, wipe dry, insert it and remove it again.
Feb 6, 2006 at 6:48 PM
JUSTINPAUL411
  • 10 POSTS
It is literally piss thin. And pretty much clear. It has never been flushed out. 74,000 miles
Feb 7, 2006 at 7:33 PM
MVANNESSJR
  • 223 POSTS
Time for a flush!
Feb 8, 2006 at 12:30 AM
Suggested Repair
Have the transmission flushed and serviced. At 74,000 miles the fluid has never been changed, is very thin, and is nearly clear instead of red. With the engine warm and running and the parking brake set, shift to drive then park and recheck the fluid level.
Conversation Summary
The owner of a 2000 Buick Park Avenue reports a mild forward jolt when shifting into drive after driving, unlike a 2002 Park Avenue. The dealer blamed poor lubrication and recommended a flush. The fluid has never been changed at 74,000 miles and is very thin and nearly clear. The expert says fluid should be red, recommends service about every 30,000 miles, and advises a flush.
