1996 Pontiac Sunfire High Beam Indicator
GMC
CARYAHOO
I have a 2.2cc 1996 Pontiac Sunfire with 380,000 km on the engine. The problem is the high beam indicator light on the dash board stays on permanently, whenever I start the car and turn low beam lights on. This happens even though I do not switch the high beam lights on. I checked the bulbs and fuse and they are ok. Please help me to correct this problem. Your help is greatly appreciated.
Sep 19, 2007 at 11:47 AM
MERLIN2021
  • 17,250 POSTS
Most likly a malfunction in the multifunction! Headlight switch that is...
Sep 19, 2007 at 11:50 AM
Suggested Repair
Inspect and, if faulty, replace the multifunction headlight switch, which is the likely cause of the high-beam indicator staying on.
Conversation Summary
The owner of a 1996 Pontiac Sunfire reports that the dash high-beam indicator stays on whenever the low beams are turned on, even though the high beams are not selected. The bulbs and fuse were already checked and found okay. The expert attributes the problem to a malfunction in the multifunction headlight switch.
