stalling
GMC
TUTTER19
I have a 2002 chevy trailblazer.When the A/C is on the engine stalls. When it is off, the truck runs fine. Does this vehicle have a IAC valve that could be causing it to stall?
Mar 18, 2006 at 12:16 PM
CHEVYMAN27
  • 8 POSTS
Sounds like there is a short with the cooling system. It is drawing to much juice to run the AC and pulling power away from running the engine.
Mar 18, 2006 at 1:03 PM
TUTTER19
I just cleaned the motor, so that could be the problem. The truck will run with the A/C on, but once I stop,the idle will drop and the engine will try and sometimes stall.
Mar 18, 2006 at 1:13 PM
CHEVYMAN27
  • 8 POSTS
You might want to have the altanator checked to see what it is putting out. At a high level it will run the vehicle, but at an idle if power is going somewhere else, it will stall out. I would check the AC fuse, make sure it can handle the right amount of current, and check all wires to and from the cooling system. After that a certified GMAC dealer will hook it up to the computer. Is it still under warrenty?? If not price it out.
Mar 19, 2006 at 2:17 AM
