GMC Spark Plug Broke Off
Suggested Repair
Determine whether only the ceramic insulator broke or the plug broke off flush. If only the ceramic broke, back the plug out with a deep-well socket. If it broke flush, use an easy-out extractor: tap it into the broken plug and turn it out with a wrench. Do not drill the plug out, because metal shavings can damage the cylinder. If extraction fails, the cylinder head may need to be removed.
Conversation Summary
The owner of a GMC (year and model not given) asked how to remove a spark plug that broke off. Experts asked whether the ceramic tip or the whole plug broke flush, then recommended a deep-well socket for a ceramic-only break or an easy-out extractor if the plug is flush. They warned against drilling because shavings can enter the cylinder and noted that head removal may be required if extraction fails.
