s-10 engine swap
2010 GMC
SLOTRACER
will a 1986 2.8 f.i. engine swap with a 1983 2.8 carb engine. will the long blocks interchange if i swap all the parts from the 83 to the 86 block?
thanks
pat(slotracer) :?:
Jan 19, 2006 at 2:34 AM
SC1 RACING
  • 117 POSTS
everything should interchange with no problems. although a v8 would be well worth the swap...
Jan 20, 2006 at 5:09 AM
SLOTRACER
i went to a engine rebuilder and the shop said a front wheel drive block is different the a rear wheel drive block. also said that a 86 block does not have a spot for a fuel pump and the cam amy be different but someone else siad the cam part numbers are the same. HELP.
PAT(SLOTRACER) :roll:
Jan 21, 2006 at 12:00 PM
