1996 GMC Pickup Won't Crank
GMC
DON TUURI
Hi! I'm new here. I have a 1996 GMC 3/4 ton 4x4 pickup with 253000 miles and a rebuilt motor. It usually runs great. Yesterday i went to start it and it turned over once and didn't start and then died. The radio and hazards and stuff work, but there is nothing when i turn over the key. Sounded simple - i pulled the battery and starter and celenoid (sp?) and took them to the store to get checked out. They all check out fine. I really cleaned all the cables and it still won't start! Seems like there is a fuse or something but i can't figure it out! I sure could use some guidance!!! Thanks!!! don
Jun 19, 2006 at 2:08 PM
SYNCRAIT
  • 235 POSTS
try turning on the ignition and run a wire from the + to the starter sylenoid and the engine should turn over.. be careful as the engine will start if this works so watch your parts...... if this is the case theres somethine wrong with the ignition if the starter dosent engage then you either have a battery or starter problem.... good luck :)
Jun 24, 2006 at 12:32 AM
Suggested Repair
With the ignition on, briefly jump battery positive to the starter solenoid S terminal. If the engine cranks, the ignition or start circuit is at fault. If it does not engage, recheck the battery and starter despite the store tests.
Conversation Summary
The owner of a 1996 GMC 3/4-ton 4x4 pickup says it cranked once, then died, and now will not turn over, although the radio and hazards still work. The battery, starter, and solenoid tested fine and the cables were cleaned. The expert suggests a careful solenoid jump test to distinguish an ignition-circuit problem from a battery or starter problem.
