1999 Pontiac Grand Am Won't Crank
GMC
MINDSTRAP
Hello, I found a deal on a 99 Pontiac Grand Am SE for sale for only 500 bucks. According to the seller, there was a screaching noise under the hood and the engine stoped running and the starter wouldn't turn over. I tried jumping it with no luck, just the starter selenoid clicking. All the power stuff seems to come on. According to the seller, there were water problems, the radiator was replaced and her uncle believes that the water pump is shot. If the pump is seized, can this prevent the engine from cranking over? Is it possible, that the anti-theft system is preventing it from cranking? or the neutral safety?
Or maybe the starter went bad at the same time?
Besides the engine being seized or blown, what are some things to check out? This 99 Grand Am has the 2.4 liter, DOHC engine. Any words of wisdom is appreciated--Thanks-- mindstrap@gmail.com
May 5, 2006 at 2:28 AM
BURRBRIAN
  • 158 POSTS
Unfortunatlly, it sounds to me like it is the engine. I would pull starter off and check it then if it's good try puuling spark plugs and turn engine over. If you still can't get it to turn you got the car cheap enough that if you like it would probably be worth the trouble of finding a good engine for it. Just my thoughts on it but that is what it sounds like to me.
Good luck and happy wrenching 8)
May 6, 2006 at 5:50 AM
Suggested Repair
Remove and test the starter. If it is good, remove the spark plugs and try to turn the engine over. If it still will not turn, the engine may be seized and a replacement engine may be the practical next step.
Conversation Summary
A 1999 Pontiac Grand Am SE with the 2.4L DOHC engine stopped after a screeching noise and will not crank; jumping only produces starter solenoid clicking while accessories still work. The seller mentioned cooling-system problems and a suspected bad water pump. The expert believes the engine itself may be seized, and recommends testing the starter, then trying to turn the engine with the spark plugs removed. If it still will not turn, a replacement engine may be worthwhile given the low purchase price.
