I caanot get 1 of the brake rotors off, it seems to be stuck. I already changed the other 3. what would help me to get it off.
May 13, 2006 at 9:34 AM
LOSONE
✓Experienced Mechanic
If all the screws that hold it on are off and everything out of the way--hit it a solid lick with a hammer on the front bottom edge. Watch out it doesn't hit you as it comes off. Good luck
May 13, 2006 at 11:41 AM
CAIN65
MEMBER
My front left brake rotor is stuck.I have sprayed it with penatrating oil,and beat the heck out of it with a mini sledge and it won't budge.There is no hold down screws as I have already changed the other side. Please help
May 14, 2006 at 6:45 AM
LOSONE
Not a clue since I am not standing there. It may require some heat where the rotor seats against the hub. What part of the world is the vehicle driven??
