2000 Pontiac Grand Prix Oil in Coolant
Suggested Repair
Stop driving the vehicle. Inspect and replace the intake manifold gasket, the most common cause of oil in the cooling system; the intake manifold itself may also need replacement. Also check for a leaking head gasket, especially if the engine overheats. Oil and coolant mixing can cause serious engine damage.
Conversation Summary
The owner of a 2000 Pontiac Grand Prix with 120,000 km was told oil was found in the cooling system and that inspecting and replacing the intake manifold would be expensive. The car still runs fine. Replies said the driver may notice little more than oil loss. A failed intake manifold gasket is the most common cause, and a leaking head gasket is also possible, more often with overheating. The advice was to repair it promptly and not keep driving because mixing oil and coolant can seriously damage the engine.
