Noise when turning right at low speed
GMC
HPDEAN
Pontiac, Grand Am, 1998, 150,000 miles. Sounds like the right front tire is rubbing on something when I turn right at low speed. I have looked and do not see anything unusual, except the front right tire is wearing out, The other tres are in good shape.
Mar 29, 2006 at 9:24 AM
JIMDELRIE
  • 10 POSTS
Thress possible problems come to mind:
- Front end is way out of alignment (take to alignment shop -- cheap fix)
- Constant Velocity (CV) joint is failing due to a broken CV joint boot or just excessive wear (check CV boots to see if they are broken or torn -- expensive fix)
- Do you have larger than recommended tires on the vehicle?
Apr 4, 2006 at 6:51 AM
