no spark 86 cammaro
1986 GMC
DRIVERDAD55
I have an 86 camaro with a 2.8 L v-6(fuel inj)
Here's the problem At times I go to start the car and it has no spark. When I check for voltage at the coil, resistance through the pick up ect. everthing check out to normal tollerances. I put the dist cap back in place and the car fires up. It will work fine for a few days then it won't start again. I've check for loose conections, replaced dist control module(3) times, replaced coil and the dist pick-up. Again after replacing these parts the car will work fine for awhile then it reverts to the no start condition. There have been times when it wouldn't start I'd leave it and go back a short time later and it starts right up. Any ideas what could be causing this? I've run out of ideas.
Jan 25, 2006 at 7:19 AM
KAZOO2281
  • 12 POSTS
to me sounds like an ecm problem or a PROM might be bad if you disconected the batt cable it resets the ecm and might cause it to spark. check sensors and ecm
Jan 25, 2006 at 10:17 AM
DRIVERDAD55
part of the problem is that when its running I'm not going to find anything, and when it doesn't start I've been unable to locate any malfunctioning parts.
Jan 28, 2006 at 2:56 AM
KAZOO2281
  • 12 POSTS
well first things first replace coil if that not the prob then there is a ignition module prob
Jan 30, 2006 at 8:32 AM
DRIVERDAD55
I replaced the coil and 3 dist control modules. If it is a control module is there anything you can think of that would be causing them to go bad
Feb 1, 2006 at 11:34 AM
CHEVY350GUY
  • 109 POSTS
it could be the distributer itself.
Feb 2, 2006 at 4:15 AM
