have you checked for the four things that it needs for this to happen fuel,air, spark, and compression.also if you have been crancking the car a lot you may hve washed the cyclinders down. which will cause loss of compression.if you have no fire try changing the module in the distribuator. if you have no fuel pressure then you have a bad pump or fuel pump relay or bad ground problem. i will try to help you as much as i can. any mor questions contact at DSR_Phantom@hotmail.com
Mar 2, 2006 at 10:15 AM
