Maybe Vacumn Problems??
GMC
MJWIDD
  • 12 POSTS
When I'm driving and let my foot of the gas, Then press the gas again it feels like it's shifting into overdrive and then it will downshift and accelerate. Sound like a vacumn leak.
Jan 19, 2006 at 12:22 PM
SC1 RACING
  • 117 POSTS
probably just the lock up converter.
Jan 20, 2006 at 5:04 AM
MJWIDD
  • 12 POSTS
where is that?
Jan 20, 2006 at 8:14 AM
SC1 RACING
  • 117 POSTS
when you let off the gas and coast the converter will unlock then when you get back on the gas the vehical is still in over drive. what you feel is the lock up converter kicking in.
if you have an overdrive transmission start out and count the times it changes. it will go to 1st, 2nd. drive, then overdrive. then the converter will lock up and it will feel like another gear. when you let off the gas the converter unlocks and it stays in o/d unless you give it alot of gas to kick down to drive.
unless it picks up rpm to 2,500-3,000 when it does this everything is fine.
Jan 20, 2006 at 8:20 AM
MJWIDD
  • 12 POSTS
Thats exactly what it does, how do I fix it?
Jan 20, 2006 at 8:22 AM
SC1 RACING
  • 117 POSTS
if the rpm jumps that high more than likely it is something in the engine. really hard to tell. you have so many options that work with when the trans shifts. do you hear any pinging noise when you are exelrating or climbing a hill? would be best to scan the computer for codes. to make sure all sensors are in good shape.
did you mean it jumps up to 2500 while gently getting back in the gas?
Jan 20, 2006 at 8:27 AM
MJWIDD
  • 12 POSTS
Scaned for codes nothing came up.
Jan 20, 2006 at 8:51 AM
