My 1992 Buick Regal Custom with 100K+ miles, left turn signal will work only when the steering wheel and turn signal lever are held in a precise position. It still flashes and will shut itself off after making a turn, and the right turn signal works perfectly. Is this a problem with the turn signal flasher, turn signal switch, or something else? Thank you!
Apr 17, 2006 at 10:45 AM
