I think there is antifreeze in my oil
GMC
SUBREW
Hi, I was driving my 2001 pontiac montana and it overheated. We put antifreeze in and it drove fine until I drove home and it started over heating again. When checking the oil there was antifreeze in it. What do you think the problem is?
Thank you,
Susan
May 7, 2006 at 6:56 PM
BURRBRIAN
  • 158 POSTS
Hi, I hate to be the bearer of bad news but you have just described the "classic" symptoms of a bad head gasket. Check your anti-freeze and see if there is oil in it. You would also get air bubbles in it with the car running. Have a good shop you trust check it out -do not drive any more than absolutly necesarry!Any more driving could cause more severe damage , stop now and all you may need is a new head gasket, oil change and anti-freeze. Good luck :cry:
May 7, 2006 at 7:54 PM
