How do i reset my Change engine oil light after changed oil
GMC
ELVISMARTE
I have a 2000 Pontiac Montana with 77,000 miles, i just changed the engine Oil and since i have changed it the change engine oil light has appeared. How can i reset the change engine oil light?
Mar 22, 2006 at 5:41 AM
  • 55,423 POSTS
With the engine off, key on, hit the thottle to the floor 5 times. Shut key off than turn back on, the light should be out.
Mar 22, 2006 at 7:59 AM
94IMPALASS
  • 12 POSTS
I have a 94 impala SS, and after you change the oil you have to go inside of the fuse panel in the passenger compartment on the drivers side. Turn the ingintion to the on position(dont start engine) then go inside the fuse panel there is a button that says(oil reset). Im pretty sure GM would have put this on most of there models,not exactly sure if your model does.
Mar 22, 2006 at 8:58 AM
  • 55,423 POSTS
Yes GM did do there service light reminder reset procedure a couple different ways, but your Montana is done the way I described earlier. :D
Mar 22, 2006 at 10:22 AM
