how do I change spark plugs on a 2001 pontiac grand am 2.4L
2001 GMC
KAREN MENNEM
I can't find in the Chiltons Mechanical Manual on what must be removed to change my spark plugs and wires.
Mar 12, 2006 at 7:19 AM
MVANNESSJR
  • 223 POSTS
There is a decorative cover with "2.4L Quad" on it, it has 4 bolts, upper left, upper right, lower left, lower right. Remove these 4 bolts and lift up. You may need to rock it back and forth so the boots release from the plugs. Once you have it off it will look like a V. The plugs are down at the bottom.
You don't have wires. Our engine uses spark plug boots.
Mar 13, 2006 at 12:24 AM
