2001 Chevy Cavalier Thump and Shake
GMC
PACKER_FAN_4
I am a typical girl. I know very, very little about cars. All I know is that my 2001 Chevy Cavalier thumps when I drive it (like when a tire is flat) yet there is no flat tire. Also, my steering wheel shakes. If anyone has any idea as to what could be wrong with my car, please let me know.
Thanks.
May 24, 2006 at 3:28 AM
BURRBRIAN
  • 158 POSTS
Look at your tires and see if you can see any unusual worn spots on them that might give you the funny feeling in your steering wheel. Then you should take it to a shop you think you can trust and have the front end alignement checked. Odds are you need a alignement, as when it gets out of line you can get a shaky feeling, also does it seem to pull one way or the other? Be sure to check the sidewalls of your tires for funny looking bubbles on them, too.You will probably need a couple of new tires after you have the alignement or you will be right back where you started from. This should have you road-ready again. Good luck :P
May 24, 2006 at 4:57 AM
Suggested Repair
Inspect the tires for uneven wear and sidewall bubbles, then have the front-end alignment checked at a trusted shop. Replace any damaged tires after alignment so the thumping and steering shake do not return.
Conversation Summary
The owner of a 2001 Chevy Cavalier reported a thumping sensation while driving, similar to a flat tire, even though no tire was flat, along with steering-wheel shake. The expert advised checking the tires for unusual wear and sidewall bubbles, noting whether the car pulls, and having the front-end alignment checked. New tires may be needed after alignment.
