heater problem
GMC
SHREK
I have a 93 grand am 3.3l .i have a bit of heat for about a minute or so after i turn on the fan.i was told that the heater core may be plugged or restricted.is this correct info or is there another problem
Jan 14, 2006 at 5:01 AM
What to check next
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
Have the coolant level and heater-core flow evaluated before authorizing heater-core replacement. Ask the technician to compare heater-hose temperatures safely; do not handle hot hoses or open a hot cooling system.
Guidance references and applicability
Source: Original question and visible replies. Owner reports and other participants' experiences are distinguished. Next steps are editorial guidance for obtaining diagnosis or clarifying the reported findings; they are not a verified repair procedure or an independently confirmed component diagnosis.
Read the replies · Discussion summary and reported outcome
PVITULLI
  • 5 POSTS
First warm up the car and turn on the heat.
Then touch the 2 hoses going through the firewall to the heater core.
If one is hot and the other is not.
You have a clogged heater core.
Also check your fluid level.
Jan 14, 2006 at 9:39 AM
Discussion summary
heater problem
The owner of a 1993 Grand Am 3.3L reported that cabin heat lasted about a minute after the fan was switched on.
Reported outcome: No test results or completed repair were reported.
A reply suggested checking coolant level and comparing heater-hose temperatures. A restriction was proposed, but the discussion does not establish a clogged heater core.
Read the original discussion
