2003 Saturn Ion No Heat or AC from Vents
GMC
GILMORE GIRLS
2003 Saturn Ion 3 29000 miles
I am having troule getting heat and air conditioning to come out of the vents? What could be the problem? Would it be covered under by warranty?
Thank You.
Apr 10, 2006 at 10:13 AM
LOSONE
  • 1,616 POSTS
The problem is vacuum isn't getting to the controls correctly or the control is defective. Check under the hood for a small 1/8" black plastic line that leads from the engine into the car in a wiring harness. The end of the lne should be connected to a vacuum source. Often the break due to heat.
Warranty?? It shoild be depending on the in service date. 3 Years and 36K
Good luck
Apr 10, 2006 at 10:26 AM
Suggested Repair
Check the small black vacuum line under the hood that runs from a vacuum source into the car through the wiring harness; it often breaks from heat. If vacuum is present, the HVAC control may be defective. Warranty coverage depends on the in-service date, typically 3 years or 36,000 miles.
Conversation Summary
The owner of a 2003 Saturn Ion with 29,000 miles reports that heat and air conditioning are not coming from the vents and asks whether warranty would cover the repair. The expert says vacuum may not be reaching the controls or the control itself may be defective, and advises checking the small vacuum line under the hood that often breaks from heat. Warranty depends on the in-service date, generally 3 years and 36,000 miles.
