1998 GMC S-10 Hard Start in Cold Weather
GMC
MINGUELLI
  • 7 POSTS
I have a 1998 s-10 pickup with a 2.2L engine, and 87000 miles on her.
For the last 2 years I put it in the garage for the winter because when the temperature outside gets between zero (0) degrees and 17 degrees above temperature, the old girl just cranks over and will not start, eventually it does after an hour or more (depending how she must feel) it does start but it is not a reliable vehicle to take to work on a cold day.
I know you need fuel and spark, at one point I had it in the garage and it was acting up (2 years ago) I sprayed some starting fluid in the throttle body, and the old girl would just crank over but no start, I took the #1 plug out to see if I had spark dried it off cranked the engine no spark. I have replaced the Ckp sensor, cmp sensor, IAT sensor, wires plugs,coil packs (2 of them), control module. It has gotten a bit better starting this year in the garage but I would like to take it out in the winter to go to work with out having to worry it wont start for a while. During the summer it starts fine. thanks for any input.
Mar 7, 2006 at 11:07 AM
MVANNESSJR
  • 223 POSTS
Did you check the output of the battery? Your battery may need to be replaced it the CCA (Cold Cranking Amps) is too low and the vehicle will not start.
Mar 7, 2006 at 11:44 PM
MINGUELLI
  • 7 POSTS
will do, check it out and see if the battery is the culpret. thanks :lol:
Mar 8, 2006 at 12:27 AM
MVANNESSJR
  • 223 POSTS
Wow, I shouldn't do posts 10 minutes after I get up in the morning. I'm surprised you were able to read that! :lol:
Let me know what you find out.
Mar 8, 2006 at 11:38 AM
Suggested Repair
Test battery output and cold cranking amps (CCA). If CCA is too low for cold-weather starting, replace the battery.
Conversation Summary
A 1998 GMC S-10 with a 2.2L engine cranks but will not start reliably between 0 and 17 degrees, though it starts fine in summer. The owner replaced the CKP, CMP, and IAT sensors, plugs, wires, coil packs, and control module, and once found no spark after using starting fluid. An expert recommended checking battery output and CCA, noting a weak battery may prevent cold starts. The owner planned to test the battery.
