GMC Pickup Poor Mileage and Fuel Leak
GMC
RAAR
I have a GMC 3/4 ton pick-up, with a 350 engine. It's sitting at about 270,000.
The truck runs great. The problem is that I can only travel 100 km per 60 litres of fuel. This seems terribly wrong. Or is this just what I have to deal with?
Apr 2, 2007 at 11:54 AM
  • 75,988 POSTS
Get a major tune-up might solve the gas guzzling
Apr 2, 2007 at 6:33 PM
RAAR
A second gas tank had been added. We had switched to this second tank to see how it was working, because we hadn't hooked up the link to switch from one to the other yet, were waiting for the spring. Went to Sarnia this weekend and had left the truck running. When coming back to the truck, I noticed a puddle beneath the truck, but on the side of the unused tank, (which was half full). I noticed where it was dripping from and took my finger, thinking it had been melting snow, but lo and behold it was gas.
I looked up and noticed that it was also leaking from the gas cap. I opened it up and gas came gushing out.
Am switching back to the original tank as we speak until it can be investigated. I'm thinking gas must be getting to the fuel pump, but any over-flow must be going into the unused tank (it is still hooked up, just not tee'd to the other tank...so for all this time, slowly building up gas and pressure...Does this sound plausible????
Apr 10, 2007 at 11:06 AM
  • 75,988 POSTS
[quote:bbb39f3969="raar"]A second gas tank had been added. We had switched to this second tank to see how it was working, because we hadn't hooked up the link to switch from one to the other yet, were waiting for the spring. Went to Sarnia this weekend and had left the truck running. When coming back to the truck, I noticed a puddle beneath the truck, but on the side of the unused tank, (which was half full). I noticed where it was dripping from and took my finger, thinking it had been melting snow, but lo and behold it was gas.
Am switching back to the original tank as we speak until it can be investigated. I'm thinking gas must be getting to the fuel pump, but any over-flow must be going into the unused tank (it is still hooked up, just not tee'd to the other tank...so for all this time, slowly building up gas and pressure...Does this sound plausible????[/quote:bbb39f3969]
Its possible-its losing pressure
Apr 10, 2007 at 11:56 AM
Suggested Repair
Switch back to the original tank and inspect the added tank's plumbing, switching valve, and venting so fuel and pressure are not forced into the unused tank. Repair the leak at the tank and cap, then perform a major tune-up to address the high fuel use.
Conversation Summary
The owner of a high-mileage GMC 3/4-ton pickup with a 350 engine reported only about 100 km per 60 litres of fuel. An expert suggested a major tune-up. The owner later found an added second tank leaking and overflowing from the tank and gas cap after it was used without the tank-switching link fully connected. The expert said fuel could be transferring into the unused tank and that the system was losing pressure.
