Hello: I assume you have a TBI injection system, not sure, you didn't say. If the fuel pressure regulator in the TBI unit is bad will cause problems. TBI units usually need only 9 to 13 pounds of fuel pressure to operate. If there is something wrong with the IGN module in the Dist it will not send Injector reference pulses causing injectors not to open. Make sure the vacuum hose to the MAP (if you have one) is not torn, gummed up or something like that. Could be several things, but checking fuel pressure is a real good start
good luck
Darryl.
Wednesday, January 18th, 2006 AT 9:09 PM
