1999 Chevy Trailblazer Low Beam Out
GMC
DRAGON
hello, 99 chevy trailblazer (has S-10 body) only driverside headlight (low beam) does not turn on. I have replaced the bulb socket, it came on for a second then went off just as fast. Manual switch doesn't turn it on either. Thanks for your help.
Jan 19, 2006 at 2:16 AM
SC1 RACING
  • 117 POSTS
did you touch the bulb? if so it will blow from the oil in your skin, also check the socket. if corroded it will short across. if it is corroded get some diode greese and install
Jan 20, 2006 at 5:10 AM
Suggested Repair
Check whether the bulb was handled with bare hands, since skin oil can cause it to fail. Inspect the socket for corrosion that can short the circuit, and if corrosion is present, clean it and apply dielectric grease.
Conversation Summary
The owner of a 1999 Chevy Trailblazer reported that the driver-side low-beam headlight would not turn on. Replacing the bulb socket made it light briefly before going out, and the manual switch did not restore it. The expert advised checking for bulb contamination from skin oil, inspecting the socket for corrosion that could cause a short, and applying dielectric grease if the socket is corroded.
