1994 Chevrolet Impala Distributor Misfire Fix
GMC
94IMPALASS
  • 12 POSTS
IF I GET MY DISTRIBUTOR WET WILL THIS CAUSE A MISFIRE???
CAN I JUST CLEAN THE CONTACTS??
OR BUY A ENTIRE DISTRIBUTOR OR JUST THE CAP AND ROTOR TO FIX THIS???
PLEASE ANY BODY.
94 IMPALA SS W/ LT1
OPTISPARK DISTRIBUTOR
May 1, 2006 at 12:41 PM
BURRBRIAN
  • 158 POSTS
Water will definitly cause misfire or lack of fire alltogether. Before you go buying a bunch of new parts you might try drying out what you have by taking a blow dryer-as in hair- and drying things out with it. I'm not sure how well it will work with what you have but us old timers did this with our points and condenser distributers back when and it worked more often than not. Worth a try, anyway. Good luck and hope this helps. :idea:
May 1, 2006 at 11:43 PM
Suggested Repair
Dry the Optispark distributor thoroughly with a hair dryer before buying parts. Water can cause a misfire or no spark; drying may restore fire without replacing the distributor, cap, or rotor.
Conversation Summary
The owner of a 1994 Chevrolet Impala SS with an LT1 Optispark asked whether a wet distributor causes misfire and whether to clean the contacts or replace the distributor or just the cap and rotor. The expert said water can cause misfire or no fire and recommended drying the distributor with a hair dryer before purchasing new parts.
