Cruise Controll Problems
GMC
BWOODY420
I own a 1995 Saturn SC2, it has 107,300 miles on it, and still runs great, i drive to and from school every day and the cruise controll has always worked fine. one day it just shut it self off and woulnt stay on for more then a few seconds, at lower speeds it would work for longer. The next day the cruise controll didnt work at all. The cruise controll setup has a indicator light on it that is lit when in the on position, and it is still working. i checked the fuse and it isnt the problem. Can anyone tell me what is wrong with it.
Thank You
Also it is a 5 speed manuel transmission
Jan 25, 2006 at 2:40 PM
What to check next
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
If adding a follow-up, state whether cruise control continued working and whether any cause for the reported low fluid level was documented.
Guidance references and applicability
Source: Original question and visible replies. Owner reports and other participants' experiences are distinguished. Next steps are editorial requests for clarification or existing diagnostic findings, not a verified repair procedure or an independently confirmed component diagnosis.
Read the replies · Discussion summary and reported outcome
BWOODY420
Nevermind, i fixed it. The clutch fluid was low so we filled the clutch fluid and tried it our and it works great. :oops: something stupid like that can really screw your vehicle up.
Jan 27, 2006 at 8:12 AM
Discussion summary
The owner of a 1995 Saturn SC2 with a manual transmission reported that cruise control began shutting off, then stopped working entirely. The indicator still illuminated, and the owner reported checking the fuse. In a follow-up, the owner said the clutch fluid had been low and cruise control worked again after fluid was added.
Reported outcome: The owner reported restored cruise-control operation after adding clutch fluid.
This is an owner-reported sequence, not a verified explanation of the fault. No diagnostic findings or longer-term follow-up established why cruise control stopped working.
Read the original discussion
