Coolant leak
GMC
1994_CAVILIER
I was loseing alot of coolant. i traced the leak to a rubber elbow located on the firewall just above the exhaust pipe. This elbow goes into the firewall but is not connected to anything inside the engine bay. Should this elbow be connected to a hose? I will double check, but i dont think that it had anything to do with the heater core. There is not a whole lot of pressure coming out of the elbow. I have a 1994 Cavilier. If pictures are needed, i can get some for tomorrow. Thanks for any and all help.
Mike
Feb 23, 2006 at 6:37 PM
HEAVYDUTY
  • 60 POSTS
It sounds like the elbow you found is the drain for water off the evaporator core for the A/C. the heater core is right next to the evap core so you probably have a leaking heater core.
Feb 25, 2006 at 4:52 PM
