Cold weather starting
GMC
DAVE COOK
My 1989 Pontiac Bonneville has a cold weather problem: It won't start, it backfires & won't run:
This is one of the nicest cars I’ve ever owned. It currently sits at 370,000 kilometres and I can see driving it past the 400k mark.
This winter a problem arose with cold weather starting. When the temperature hits minus 18C (0F), the engine turns over fine but the car reacts like it’s being flooded. It just about starts then violently backfires and the engine stops dead. I’ve ruled out all of the following (a costly venture to be sure) -- heat sensor, crank sensor, computer, timing chain, ignition module, injectors.
My mechanic is baffled. So am I. Any ideas... please?
Dave Cook, cecild@shaw.ca
Mar 23, 2006 at 12:03 PM
POWER6
I have a 1990 bonneville SSE. Same problem, no one has any idea, and the engine light does not come on. I have to plug the block heater in for at least a half hour to get it started. So you would think that it has something to do with a temp sensor. I have replaced one of them, but it turns out i replaced the one sending signal for the gauge only!! If you have any luck with your car, let me know, I will do the same for you. Good luck.
Mar 25, 2006 at 11:59 AM
DAVE COOK
[quote:bfc59a7d74="power6"]I have a 1990 bonneville SSE. Same problem, no one has any idea, and the engine light does not come on. I have to plug the block heater in for at least a half hour to get it started. So you would think that it has something to do with a temp sensor. I have replaced one of them, but it turns out i replaced the one sending signal for the gauge only!! If you have any luck with your car, let me know, I will do the same for you. Good luck.[/quote:bfc59a7d74][quote:bfc59a7d74]
My problem seems to have been solved. I basically changed out everything I could think of including the computer. My mechanic installed what he called a new "prom" in the computer. I have never heard of such a thing. It apparently is a perfomance modifyer. He says that the prom he replaced is one-step above the stock version. This prom is a plug-in module about the size of a small candy bar. So far, so good....And we've had some early winter weather here. If you want my mechanic's number, please email me at cecild@shaw.ca
dave cook[/quote:bfc59a7d74]
Nov 15, 2006 at 4:26 PM
