clutch has no pressure 1991 brettea gtz
1991 GMC
GMAN
i have no presure on the clutch pedel and there is no leaks, i have no idea what could be wrong please help. and the fluid is full.
Jan 14, 2006 at 11:07 AM
What to check next
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
Clarify whether the clutch disengages and whether gears can be selected, then have the clutch hydraulic system and release mechanism diagnosed before choosing parts. Avoid driving if clutch control is unreliable.
Guidance references and applicability
Source: Original question and visible replies. Owner reports and other participants' experiences are distinguished. Next steps are editorial guidance for obtaining diagnosis or clarifying the reported findings; they are not a verified repair procedure or an independently confirmed component diagnosis.
Read the replies · Discussion summary and reported outcome
DARRYL
  • 61 POSTS
Hello: sounds like you have a hydraulic clutch linkage mechanism, thats to bad, the old mechanical kind always worked. Well two possibilities. The master cylinder for the clutch is shot, or the slave cylinder for the clutch is shot. If you have a hydraulic throw out bearing then is would be the same as a slave cylinder. You did not say if the clutch works properly or not. If the clutch appears to work properly but seems pedal pressure had dropped, then I would suspect the pressure plate has lost some of its spring pressure ability. This may cause the clutch to slip more than usual it would seem.
good luck
Darryl...
Jan 14, 2006 at 3:17 PM
Discussion summary
The owner of a 1991 Beretta GTZ reported no pressure at the clutch pedal, a full fluid reservoir and no observed leaks.
Reported outcome: No diagnosis or successful repair was reported.
The reply proposed a master-cylinder or slave-cylinder problem and discussed pressure-plate issues conditionally. None of these possibilities was confirmed.
Read the original discussion
