1989 Chevrolet pickup (Silverado trim) Odometer Shows Repeating Nines
1989 CHEVROLET PICKUP (SILVERADO TRIM)
REALST8
I removed the instrument cluster on my 89 Chevy Silverado to repair the odometer(hasn't moved in about 4 years). I found a broken plastic gear and was able to glue it back together and reassemble the cluster. Problem is now I get an error code of repeating 9's. How do I clear this?
Mar 26, 2006 at 1:07 PM
DEERAYROSE
  • 25 POSTS
The lower portion of this link may have some information pertaining to your question. That code 9 thing was a bit difficult to get any answers on.
Fault codes
Codes for Dodge RWAL, Ford RABS and GM RWAL applications are similar but have a few differences:
1. Should not occur (replace the controller if it does)
2. Open isolation valve circuit or defective ABS module
3. Open dump valve circuit or defective ABS module
4. Grounded or closed RABS or RWAL valve switch
5. Excessive actuations of dump valve during ABS braking
6. Erratic speed sensor signal
7. Shorted isolation valve or defective ABS module
8. Shorter dump valve or defective ABS module
9. High resistance or open speed sensor circuit (resistance should be 1000 to 2500 ohms)
10. Low speed sensor resistance (Dodge & Ford only)
11. Open speed sensor circuit (GM only)
12. Stop lamp switch circuit (Dodge & Ford)
13. ABS module speed processor (Dodge & Ford only)
14. ABS module program (Dodge & Ford only)
15. ABS module RAM memory failure (Dodge & Ford)
Mar 26, 2006 at 8:26 PM
