1935 GMC Knock After Warm-Up
1935 GMC
BURRBRIAN
  • 158 POSTS
Hi, I have a sb 350 that I just put new cam and lifters in because I had a tap-knock when I would hit about 2000 rpm, thought it took care of problem as a cam lobe was wore down almost round and lifter was dished on the bottom. But now it runs lot better and I still have the knock after warming up,
anybody think that I might have some bad rod bearings? I hit the throttle and it starts in, let up and eases up, feather the gas and it comes and goes.
Motor is nothing complicated, carb, headers, no cat. converter or any of that stuff. Old fashioned and easy to work on. Any old gearheads have any ideas? :shock:
Apr 11, 2006 at 11:32 AM
LOSONE
  • 1,616 POSTS
Sounds right. It is easy to drop the pan and replace the rod bearings. Replace the oil pump with a high volume while you are at it. Good luck
Apr 12, 2006 at 6:05 AM
BURRBRIAN
  • 158 POSTS
Thanks, Lee. That is pretty much what I thought I had but when I had the motor out and found the cam and lifters I thought that was it and like a dumb#&*#&* didn't keep digging and put motor back in. Never knocked during cam break-in and sounded good but by the next day-well you know the story. Think I'm gonna pull it again as I tried to check the bearings by just dropping pan, got a little uncomfortable. Has been knocking long enough that it might have got to crank, not sure which rod it is, eithier. So might have to put new crank in, can get recon one for 82.00-40$core. Looks like another fun weekend as I have to have truck mon. morn for work.
YEE-HAW!!! :twisted: Okay, all is sais and DONE on this problem- we can delete this now, somehow I can't seem to manage it this time so if a moderator wishes to go ahead and get rid of it. Oh, btw-Lee thanks for confirmation, nailed it and put melling high volume pump in and are running 65 lbs. at start-up and 25-30 lbs. at hot idle, better than I have since rebuild 2 years ago, thanks again and catch you around the site later :twisted:
Apr 12, 2006 at 11:07 AM
Suggested Repair
Drop the oil pan, replace the rod bearings, and install a high-volume oil pump. Inspect the crank if the knock has continued long enough to damage it.
Conversation Summary
A small-block Chevy 350 still knocked after warm-up under throttle even after a worn cam lobe and dished lifter were replaced. An expert said the symptoms fit rod bearings and recommended dropping the pan to replace them and installing a high-volume oil pump. The owner later confirmed that repair, including a Melling high-volume pump, and reported about 65 psi at startup and 25-30 psi at hot idle.
