brakes
GMC
6DROBLES
how do you remove rear brake pads on a 1997 buick riviera
Feb 15, 2006 at 8:48 AM
FISHERMAN
  • 937 POSTS
Hard to explain with words but the way i do it its blocking the front wheels good then raise your car and put the towers on both back wheels and remove just one side (the brake pads and all the springs) and keep the another side as reference that way you can compare what you are doing, doing brakes is not as easy as it looks you have to be trained and work with confidence, one single mistake can cause an accident!
if you are not familiar with the mechanical work take it to a service shop.
Manuel.
Feb 15, 2006 at 9:01 AM
Discussion summary
brakes
The driver asked how to remove the rear brake pads on a 1997 Buick Riviera. The post contained no description of symptoms, prior attempts, tools used, or parts condition; no chronology or follow-up from the poster was provided.
Reported outcome: The poster did not report any results, attempted repair, or resolution in the thread.
Read the original discussion
