Blower doesn't work
GMC
JPATT2020
I have a 95 astro with about 130k miles and the blower just recently stopped working on all four speed settings. I checked the fuse block under the dash and everything is fine. Where is the blower relay located? Could this be the problem, or should i just go right to the blower motor since this may have caused the electrical problem in the first place?
Jan 17, 2006 at 6:31 AM
HOTWHEELSGMC
  • 31 POSTS
most likely it's your blower motor, I had to replace it on my 88gmc truck. it's located under the dash. you can pull it out and test it at any autoparts store. It could be your fuse but doubt it.
Jan 17, 2006 at 10:23 AM
