2001 Pontiac Grand Prix Battery Removal Fix
ROBBIE
How do you remove the old battery from a 2001 Pontiac Grand Prix?
Apr 14, 2006 at 7:00 AM
LOSONE
  • 1,616 POSTS
Remove the support rod, take off the plastic cover. use an 8mm (5/16) wrench and disconnect both cables, the negative first. Lift the battery out. Watch your fingers, it's a tight fit. Good luck
Apr 14, 2006 at 10:24 AM
Suggested Repair
Remove the support rod and plastic cover. Disconnect both battery cables with an 8mm (5/16) wrench, negative first, then lift the battery out carefully because the fit is tight.
Conversation Summary
The owner asked how to remove the battery from a 2001 Pontiac Grand Prix. The expert advised removing the support rod and plastic cover, disconnecting both cables with an 8mm wrench starting with the negative, and lifting the battery out while watching fingers because of the tight fit.
