'88 Buick Electra cuts off when cornering?
1988 GMC
JAKAL
My 1988 Buick Electra with a 3.8L engine loves to cut off when i'm turning a corner, parking at low speeds, and after i turn a corner. It doesn't matter if the fuel tank is low or full either. Also, the engine is hard to start if it sits for a while, but after sputtering for about 5 seconds, it idles normally. I already replaced the crank position sensor which didn't help any.
I can't keep replacing parts on it, as i'm just a poor college student, and this is my only means of transportation. Help?!
Apr 30, 2006 at 8:30 AM
JAKAL
I'll try to post some check engine codes soon if there are any, if that will help. I tried to get some codes from it the other day, but apparently, the check engine light is burnt out :\
Apr 30, 2006 at 2:01 PM
