I have blown out the fuel lines from the tank selector valve going to the carb and fuel pump.
What did you use here? You will hear gushing noise when air is passing thru the lines-if you do it means the lines are clear.
Have you check the fuel pump pressure? If so with the correct pressure, you have a problem with the carb.
Monday, November 5th, 2007 AT 2:10 PM
