it started a year ago i could start it but could not move the shifter lever so i took off a part that kept the lever from moving i guess it was tied together with the brake some how.any way it has been starting with a delayed effect when you turn the ignition it takes a long time to start as if it was out of gas or like in my old gmc 1979 pickup the ignition module was bad.but somtimes it starts with in 1 or 2 times it turns over.and now as of a week ago it just suddenly did not start ti was running just 3 minutes before so i removed the starter to have it checked out and it was good,tried a new ignition reley but it still did'nt start put the old one on and removed the ignition switch from column put the same one back in and tried tracing the purple wire from the solenoid on the starter but didn't find and breaks or burns
Jan 12, 2008 at 9:58 AM
