1999 Other GMC Models Truck sputters and bogs down when give
1999 GMC
175,000 MILES • V8 • 4WD • AUTOMATIC
TASTARR
I have a1999 GMC Suburban with 175k miles. I've taken good care of it but now I have an odd problem that's getting progressively worste.
When I start the truck or start to go from a stop, I give it gas and it sputters and looses power. If I flutter the gas pedal I can nurse it up in RPM until it revvs up just fine and I can sail along until I stop again. If I try to give a lot of gas when it's bogging down, it will pop a bit and backfire a small amount before dying.
This has gone over a few days from just when I started it, acting like this, to now, where every stop causes it.
Any idea as what could be causing this problem? I haven't run low on fuel lately and I put a fuel filter in last year.
Jul 30, 2008 at 1:11 AM
MMPRINCE4000
  • 8,548 POSTS
Check the throttle position sensor, you could get a free scan at most auto parts stores. Get the live data feed and write down all the sensor parameters, also check error codes.
It is also a good idea to check fuel pressure with a mechanical gauge.
Jul 30, 2008 at 11:25 PM
TASTARR
Here's one for the rule of check the easiest thing first -
My K&N popped off the throttle body and no air was going past the mass air flow sensor so the computer was freaked out. Once I reattached it, viola! it worked good as new!
Jul 31, 2008 at 1:16 PM
