1999 Other GMC Models no power when cold
1999 GMC
136,000 MILES • V8 • 4WD • AUTOMATIC
PAYLONE20
when engine is cold it runs real rough. no power back fires. when warm runs better but not full power. i have changed mass air senser, egr valve throttle position senser plugs wires, checked pressure in cats and fuel pressure is good, and i changed fuel filter can u please help
Sep 27, 2009 at 8:47 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Have you checked for codes? What is engine compression? Assume all the parts replaced made no difference? Any backfiring? Loss of fuel milage?
Let me know
Thanks for donate
Sep 27, 2009 at 9:13 AM
PAYLONE20
yes i have checked for codes no codes. and have had it hooked to computer when it is doing it. could u give me anything else.
Sep 27, 2009 at 9:26 AM
DOCFIXIT
  • 18,828 POSTS
Would you answer all questions please need all info I can get to help
Sep 27, 2009 at 9:37 AM
PAYLONE20
yes i have had a compression test done on it. what other info do u need to no. i have tried everything that i could think of please help
Sep 27, 2009 at 3:45 PM
PAYLONE20
yes it also backfires and fuel milege is below par for sure.
Sep 27, 2009 at 4:44 PM
DOCFIXIT
  • 18,828 POSTS
Ohm check two sensors the Engine coolant temp and Air intake temp sensor. The ECT is next to thermostat and IAT in air intake. They should ohm out at 86 degrees- 2238 ohms, 104 degrees-1459 ohms, 212 degrees- 177ohms.
Sep 28, 2009 at 1:52 AM
