1998 Other GMC Models turns over wont starta
1998 GMC
MEEWEN
Engine problem
1998 Other GMC Models 199000 miles
I have a gmc savanah box van and it wont start, it turns over but noting, some one said the coil is bad, but there is spark. Also ran a diagnostics on it and no codes
Feb 9, 2008 at 3:35 AM
M8TRIX01
  • 36 POSTS
You probably are not getting fuel to the engine. An easy way to check is by using a can of carberator cleaner. Remove the air intake hose and spray some cleaner in while someone cranks the engine and if it starts for a second then you are not getting fuel and we can go from there.
Feb 9, 2008 at 5:14 AM
