1998 Other GMC Models im having a problem
1998 GMC
CRAFTMASTER86
Engine Mechanical problem
1998 Other GMC Models V8 Four Wheel Drive Automatic
i am haveing a problem getting my spark plug wires back in order to my distributer cap i forgot the order it goes on any one know how to help me get it back in order?
Jul 28, 2010 at 4:42 PM
  • 75,988 POSTS
Can you describe your vehicle properly-maybe I can assist you with your problem-I need to know the what type of GMC model and liter engine.TY
Jul 28, 2010 at 5:03 PM
CRAFTMASTER86
it is a 1998 gmc seirra 4x4 5.7 lit , all i need is to get it back in time because i replaced the distibutor and the cordor on the truck i think i got it out of time. how do i get it back in time?
Aug 1, 2010 at 5:22 AM
  • 75,988 POSTS
1st you have to put engine no.1 piston on compression stroke/TDC line the crank pulley to timing marks to TDC/0 Deg, pull the distributor out and restab back in making sure the rotor is pointing to no.1 cap tower this is a must-then use a timing light to time the ignition
Aug 1, 2010 at 9:35 AM
