1996 Other GMC Models Fuses
1996 GMC
JESSICA88
Electrical problem
1996 Other GMC Models 6 cyl Front Wheel Drive Automatic 157K miles
I was in my car and i was playing the radio and cleaning the interior. So my buick up and it ran just fine. So then i turned it off and continued cleaning my car. So some of my friends came by and i showed them the car and i started it up and it worked just fine, so i turned it off and i noticed that the windows were down so i turned the key over just enough to just roll down my two front windows and so i started to roll them up and then they just quit working and now my car won't start up and the power seats and windows aren't working either and it seems like the car was wanting to turn over but nothing was getting it the kick to turn over and start. so i checked the battery and the battery works just fine.Then we started to think it was the fuses so we checked under the hood to look at the relays and they worked just fine. so we checked under the driver side and the fuses were fine too. So what im asking is what fuse would it be under the passanger side or what is wrong with it.
I have a 1996 buick Park avenue V6 3.8 motor. And i appreciate if you could help me out on this one. I just can't find out what is causing my windows not to work or my seats. and even better my car not to run.
Apr 4, 2009 at 4:45 PM
MICKEY-D
  • 304 POSTS
I really think you have a bad battery. Try to jump start the car, if it starts, replace the battery. I believe it shorted, and dies under a load.
Jan 17, 2010 at 1:14 PM
