1995 Other GMC Models Rear Air Conditioner is blowing hot no
1995 GMC
93,000 MILES • V8 • 2WD • AUTOMATIC
TWITTARS
I have a 1995 gmc 2500 vandura, customized by Explorer. It has a rear air conditioner with the blower control up front and the temp. control is combined with the front (1 control for both). The front blows cold but the rear blows warm untill the engine gets hot, then it blows hot. The rear fan is mounted behind the heater core which is behind the radiator hoses. As those hoses get hotter the air from the vents gets hotter. I cant figure out if something is not engaging or if I need to add insullation to those hoses, or what. Please Help Me.
Apr 23, 2009 at 12:18 PM
JDGM3NT4L
[quote:f5b1efc2c5="twittars"]Air Conditioning problem
1995 Other GMC Models V8 Two Wheel Drive Automatic 93000 miles
I have a 1995 gmc 2500 vandura, customized by Explorer. It has a rear air conditioner with the blower control up front and the temp. control is combined with the front (1 control for both). The front blows cold but the rear blows warm untill the engine gets hot, then it blows hot. The rear fan is mounted behind the heater core which is behind the radiator hoses. As those hoses get hotter the air from the vents gets hotter. I cant figure out if something is not engaging or if I need to add insullation to those hoses, or what. Please Help Me.[/quote:f5b1efc2c5]
Good question. My '02 Montana is doing the same thing. Anyone with any ideas? I have found the blower motor for the rear, just not sure about whether there is a switching vavle that needs a beating or what. Thanks in advance for any help. If I manage to solve it I will be sure to post. Good luck twittars, let us know if you find anything.
May 23, 2009 at 5:38 PM
