1995 Other GMC Models jimmy fuel pump
1995 GMC
158 MILES • 6 CYL • 2WD • AUTOMATIC
RMCDONALD
The pass days my fuel pump was sounding alittle different now my truck want crank it turns over is it because my fuel pump went bad or my fuel pump reley went bad but i have a feeling its my fuel pump. 95 GMC JIMMY 2 WHEEL DRIVE 4.3 liter
Jul 29, 2010 at 9:12 AM
  • 75,988 POSTS
If you can hear it when you turn key on-check the fuel pressure with a gauge to rule it out
Jul 29, 2010 at 9:47 AM
RMCDONALD
I do not here the fuel pump come on anymore when i turn the key over is it because the fuel pump went bad
Jul 29, 2010 at 9:55 AM
  • 75,988 POSTS
Check the fuel pump fuse and fuel pump relay before you drop the tank
Jul 29, 2010 at 9:59 AM
