1995 Other GMC Models fluid capacity
1995 GMC
189,000 MILES • V8 • 4WD • AUTOMATIC
DASOLOMON
How much quarts does this automactic transmission holds.
Feb 9, 2008 at 10:22 AM
MASTERTECHTIM
  • 4,750 POSTS
well the entire system holds about 12 quarts, but if you remove the pan and change filter, you will only need about 4 or 5. i start by adding 4 quarts then run the vehicle then top it off. hope this helps
Feb 9, 2008 at 10:28 AM
