1995 Other GMC Models dash gauges
1995 GMC
14,000 MILES • 6 CYL • 2WD • AUTOMATIC
SCOTT 38
i have a 1995 gmc g30 van with diesel motor..it has 140k, and runs and drives fine.. i just purchased it at an estate sale.. when i got it, the fuel gauge is pegged past full..oil pressure at 0..temp is redlined.. battery at 0.. where to start looking?? grounds? fuses? new cluster?? i am handy with meter, just need advice in which direction to go.. thanks
Jul 10, 2009 at 5:46 PM
MICKEY-D
  • 304 POSTS
Start with the fuses, then check the plug in harness to the rear of the dash panel. It plugs into the rear of the panel, and will sometimes pull out a little on one side. You can also check each pin in the harness for power if you unplug it, it could be the circuit board.
Jan 11, 2010 at 10:55 PM
