1995 Other GMC Models bad miss
1995 GMC
110,000 MILES • 6 CYL • 2WD • AUTOMATIC
HAROLD75
van ran fine today when started it was rough and sounded like it was running on a couple of cylenders
so i replaced the plugs wires rotor cap coil sounds a little better but still nothing if i give it gas it sounds fine but at idle it wil not run dies after a few seconds
cold or worm
Dec 28, 2007 at 10:33 AM
BLACKOP555
  • 10,386 POSTS
check your IAC valve and clean out the throttle body.
also check the EGR valve and PCV valve.
Dec 28, 2007 at 11:44 AM
2CARPRO JACK
  • 11,533 POSTS
Runs then dies? check fuel pressure. Does it have black smoke out the tailpipe when it does run? Those CPI engines had alot of problems with injectors and fuel pressure regulators
Dec 30, 2007 at 12:39 AM
BLACKOP555
  • 10,386 POSTS
what the hell post did i answer! listen to jack.
Dec 30, 2007 at 1:17 AM
2CARPRO JACK
  • 11,533 POSTS
LOL
Dec 31, 2007 at 12:35 AM
