1994 Other GMC Models water leak
1994 GMC
ZIPPOCHEVY2002
1994 Other GMC Models V8 Front Wheel Drive Automatic
My van has a serious leak in it. We fill the radiator with water in the morning and it leaks extremely bad until we start it and then it stops leaking. any ideas?
Sep 10, 2008 at 4:35 AM
PEAR69
  • 1,482 POSTS
Check the hoses for leaks. Where is the water leaking from? Is it leaking on the grouind? Does it stop leaking because all the water runs out when you start it?
Sep 10, 2008 at 4:46 AM
ZIPPOCHEVY2002
it leaks near the radiator. It doesn't stop leaking because it runs out of water it just stops leaking when its running. and yes it leaks out to the ground. Thank you for helping?
Sep 10, 2008 at 4:52 AM
PEAR69
  • 1,482 POSTS
Check the radiator hoses carefully for leaks. It sounds like a hose is leaking. Sometimes the leak in a hose cannot be seen so look carefully.
Sep 10, 2008 at 4:59 AM
ZIPPOCHEVY2002
thank you so much for your help. We will check carefully.
Sep 10, 2008 at 5:03 AM
