my gmc pick up has water coming from the back of the carb.does this sound like a cracked block to you?
Apr 13, 2007 at 1:30 PM
Confirm whether the coolant is actually coming from the rear of the intake manifold rather than the carburetor. Inspect the intake manifold end-port gaskets, which can leak coolant, and replace them if leaking.
The owner of a 1992 GMC pickup reported water coming from the back of the carburetor and asked whether that indicated a cracked block. The expert said coolant should not be near the carburetor and suggested the leak may be at the rear of the intake manifold, where end-port intake gaskets can leak coolant.
